ViennaAudio
Block design
i'm designing my block design for my application,
said that i'm going to use a zybo7 board and my design requires to
control an external adc, external audio in/out codec, external dac, (all 3 SPI) , an external mux, zynq xadc, dram, bram ,uart.
i should use the following blocks:
zynq processing system, mig, bram generator, axi quad spi, axi gpio, axi uartlite, axi timer , xadc wizard.
Is that correct?
u4223374
Advisor
Advisor
You won't need the MIG (the Zybo doesn't have any RAM that's directly-accessible from the PL, only the DDR that's attached to the PS). You may or may not need the AXI UART and AXI SPI; depending on where the devices are connected you might need to use the UARTs and SPI controllers built into the PS.
u4223374
Advisor
Advisor
ViennaAudio
thx for your reply, talking about zybo since i got multiple errors in vivado, i got to know that the board has an hardware errata, so i thought to go for a MYIR or a trenz platform.
Do you know of any issues with z-turn board or MYD-Y7Z010/20 for example?
i uploaded z-turn board files, but i get errors when using zinq ip .
also trenz TE0725 TRM is interesting for my project. Could you suggest me something else in that range?
