Bootrom implementation
could somebody from Xilinx reveal the internal implementation
of the Zynq7000 BootROM? I need to know whether it is mask-programmed
(and hence stable no matter what), antifuse or a factory-programmed flash
which will leak its content eventually. This is very important for me from the
long term reliability perspective.
A Zynq would be a great part for the job, but if it contains some stored charge
circuitry, I'm willing to downgrade to something purely SRAM-based, say, Spartan 3.
Mask TSMC ROM,
From their SC library.  For reliability details, please request it from your local sales office,  NDA required.
Sounds like a security question, not reliability.
Your local sales office will help you with that, as well.
Safety Critical system requirements also.
Austin Lesea
Principal Engineer
Xilinx San Jose
Mask TSMC ROM,
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank you very much, Austin! That statement removes all my doubts.
And no, it's all about pure reliability. The bitstream may be unencrypted, not an issue here.
The FPGA will be configured from a voting memory module in order to withstand a single
flash chip failure. Any your internal flash involved in the boot process would introduce a weak
link. Fortunately, it is not the case.
