CAN controller does't work in NORMAL MODE
I'm trying send and receive CAN frames on ZC702. When I use demo Peripherals Test, CAN is in LOOPBACK mode and it works. But I want to comunicate with external CAN controller (CAN J52 header). What shall I change in code?
In this topic http://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/CAN-controller-issue-on-ZC702/td-p/276886 is similar problem, but I don't know, how to set MIO9 pin low.
I've solved my problem.
1. In function  CanPsPolledExample() change 2 lines to NORMAL MODE:
XCanPs_EnterMode(CanInstPtr, XCANPS_MODE_NORMAL);
while(XCanPs_GetMode(CanInstPtr) != XCANPS_MODE_NORMAL);
2. turn off stand by mode on TI CAN controller (pin MIO9, LOC=C4)
//declaration variables:
static XGpioPs PsIO; // MIO and EMIO
XGpioPs_Config* PsIO_ConfigPtr;
//inicialization:
PsIO_ConfigPtr = XGpioPs_LookupConfig(XPAR_PS7_GPIO_0_DEVICE_ID);
     if(PsIO_ConfigPtr == NULL){
        print(" PS GPIO INIT FAILED \n\r");
        return XST_FAILURE;
int xStatus;
 xStatus = XGpioPs_CfgInitialize(&PsIO,
 PsIO_ConfigPtr,
 PsIO_ConfigPtr->BaseAddr);
  if(XST_SUCCESS != xStatus){
//set MIO9 low:
XGpioPs_SetDirectionPin(&PsIO, 9, 1);
XGpioPs_SetOutputEnablePin(&PsIO, 9, 1);
XGpioPs_WritePin(&PsIO, 9, 0);
Then CAN works with external device.
//inicialization:
        return XST_FAILURE;
int xStatus;
 PsIO_ConfigPtr,
//set MIO9 low:
would you kindly send your complete c file. I'm looking for this solution for quite some time. thanks very much in advance
it works now,
just need to include the gpio header files in the program
