CPU Debugger on Kintex7 FPGA
I have KC705 evb and I want to use KEIL/ARM ULINK debugger for CPU debugging on the device.
The Ulink is conected using JTAG protocol to the FPGA I/O pins, the SDK recognize the ARM Device as shown in the attached figure.
The ARM/KEIL uVision5 SDK doesn't succeed to program nor enter the debugging mode.
Error msg are:
- invalid ROM Table
- error: flash download failed - Target DLL has been cancelled.
I've tried to set the memory addresses, it didn't help..
Eran
Re: CPU Debugger on Kintex7 FPGA
Hi erannanolock2018,
Which embedded processor do you have in the Kintex FPGA?
Andres
