Anonymous
Not applicable
Can a single ACE file be used to load both PPC440 and MicroBlaze (ml507)
I familar with the use of genace.tcl to generate an ACE file for single processor design.  Is there a way to generate a single ACE file that will load both a PPC440 and Microblaze processor.  I'm developing on the ml507 eval board.
htsvn
I have never tried it earlier,
But it seems to be available in the topic Multi-Processor System Configuration of the GenAce unit of est_rm.pdf.
htsvn
Anonymous
Not applicable
Thanks for pointing me to the correct documentation and for the quick response!  Works as advertized.
