Can anyone help me with IIC ip core?
I really appreciate if someone can help me, because I have been confused almost one week. Sorry for my poor English
I use IIC ip core under EDK. I have writen a driver, but I found it doesn't work.
I just use code like this:
send_cnt = XIic_Send(XPAR_XPS_IIC_0_BASEADDR, ADDR_DECOD, send_data, 2, XIIC_STOP);
So under SDK, I debug it, I found the code just stop here (inside xiic_l.c file)
StatusReg = XIic_ReadReg(BaseAddress, XIIC_SR_REG_OFFSET);
while ((StatusReg & XIIC_SR_BUS_BUSY_MASK) == 0) {
 The debug information showed: StatusReg = 64, and the whole program just stay here and no longer go any more. I checked the Xilinx IIC core pdf: http://www.xilinx.com/support/documentation/ip_documentation/xps_iic.pdf in page 16
I found this line actually check whether IIC bus busy or not. but here if I want to send the data, don't I want to make sure the bus is not busy? Is there anything wrong with Xilinx library?or what should I do to fix it?
Thank you very much!
sniu@hawk.iit.edu
Re: Can anyone help me with IIC ip core?
I forget to say that even I run a example iic code under installation file, the program still stop there. Thank you very much
我也遇到了类似的问题 你后来是怎么解决的呢
Did you ever figure out the answer to this problem? I have the same issue.
Please post new query about IIC IP issue seen with details of version of core, tools and OS used.
Praveen
IIC can be tricky,
1 use an oscilloscope and check if SDA SCL lines are high (check if pull up is working)
2 Check if you addressed correctly the device
3 do not debug inside IIC library functions, it will loop forever
4 after you see a failure, do not try to reprogram only the code, you 'll need to restart all the board because you can't reset your slave device and the IIC bus could be always busy
I figured out the solution. I was not setting up the transmit properly. Here are the TX and RX functions I wrote that are working:
* This function writes a buffer of bytes to the IIC bus.
* @param	AX_IIC_BASE_ADDRESS contains the base address of the AXI IIC Block. This is not the same as the device ID.
* @param	i2c_device_address contains the address of the device we will be transmitting to
* @param    internal_register_address is the address of the register inside of IC we would like to write to
* @param	tx_buf contains the number of bytes in the buffer to be transmitted (typically a register address we want to read)
* @param	tx_size contains the number of bytes in tx_buf
* @return
* 		-XST_SUCCESS if Successful else XST_FAILURE.
int PL_AXI_I2C_TX(int AX_IIC_BASE_ADDRESS, u8 i2c_device_address, u8 internal_register_address, u8 *tx_buf, u16 tx_size)
	volatile unsigned SentByteCount;
	volatile unsigned AckByteCount;
	u8 WriteBuffer[sizeof(internal_register_address) + tx_size];
	int Index;
	 * A temporary write buffer must be used which contains both the address
	 * and the data to be written, put the address in first based upon the
	 * size of the address for the EEPROM.
	WriteBuffer[0] = (u8)(internal_register_address);
	 * Put the data in the write buffer following the address.
	for (Index = 0; Index < tx_size; Index++) {
		WriteBuffer[sizeof(internal_register_address) + Index] = tx_buf[Index];
	 * Set the address register to the specified address by writing
	 * the address to the device, this must be tried until it succeeds
	 * because a previous write to the device could be pending and it
	 * will not ack until that write is complete.
	do {
		SentByteCount = XIic_Send(AX_IIC_BASE_ADDRESS,
					i2c_device_address,
					(u8 *)&internal_register_address, sizeof(internal_register_address),
					XIIC_STOP);
		if (SentByteCount != sizeof(internal_register_address)) {
			/* Send is aborted so reset Tx FIFO */
			XIic_WriteReg(AX_IIC_BASE_ADDRESS,  XIIC_CR_REG_OFFSET,
					XIIC_CR_TX_FIFO_RESET_MASK);
					XIIC_CR_ENABLE_DEVICE_MASK);
	} while (SentByteCount != sizeof(internal_register_address));
	 * Write a page of data at the specified address to the EEPROM.
	SentByteCount = XIic_Send(AX_IIC_BASE_ADDRESS, i2c_device_address,
				  WriteBuffer, sizeof(internal_register_address) + tx_size,
				  XIIC_STOP);
	 * Wait for the write to be complete by trying to do a write and
	 * the device will not ack if the write is still active.
	do {
		AckByteCount = XIic_Send(AX_IIC_BASE_ADDRESS, i2c_device_address,
					XIIC_STOP);
		if (AckByteCount != sizeof(internal_register_address)) {
	} while (AckByteCount != sizeof(internal_register_address));
	 * Return success if number of bytes written includes size of i2c_device_address
	 * and tx_size
	if(SentByteCount != (sizeof(internal_register_address)+tx_size)){
		return XST_FAILURE;
	return XST_SUCCESS;
* This function writes a buffer of bytes and reads the returned bytes on IIC bus.
* @param	AXI_IIC_BASE_ADDRESS contains the base address of the AXI IIC Block. This is not the same as the device ID.
* @param    internal_register_address is the address of the register inside of IC we would like to read from
* @param	rx_buf contains the number of bytes in the buffer to be received
* @param	rx_size contains the number of bytes in rx_buf
* @return
int PL_AXI_I2C_TX_RX(int AX_IIC_BASE_ADDRESS, u8 i2c_device_address, u8 internal_register_address, u8 *rx_buf, u16 rx_size)
	volatile unsigned ReceivedByteCount;
	u16 StatusReg;
	 * A repeated stat condition is manditory for certain ICs
	do {
		StatusReg = XIic_ReadReg(AX_IIC_BASE_ADDRESS, XIIC_SR_REG_OFFSET);
		if(!(StatusReg & XIIC_SR_BUS_BUSY_MASK)) {
			ReceivedByteCount = XIic_Send(AX_IIC_BASE_ADDRESS,
							i2c_device_address,
							XIIC_REPEATED_START);
			if (ReceivedByteCount != sizeof(internal_register_address)) {
						XIIC_CR_REG_OFFSET,
						XIIC_CR_REG_OFFSET,
	} while (ReceivedByteCount != sizeof(internal_register_address));
	 * Read the number of bytes at the specified internal address.
	ReceivedByteCount = XIic_Recv(AX_IIC_BASE_ADDRESS, i2c_device_address,
					rx_buf, rx_size, XIIC_STOP);
	 * See if we got all byes back that we expected.
	if(ReceivedByteCount != rx_size){
		return XST_FAILURE;
	return XST_SUCCESS;
