Voyager
Voyager
Can someone spot my silly mistake in microblaze SPI code?
I have been struggling with a simple microblaze project on a custom board recently and I am sure it is more user errors on my part.
I have a SPI microblaze core setup to talk to an ADC on a board.  I used code from examples, but something is still not right (though it compiles and debugs OK).  What bothers me is that if I write to a register a value, and then read from it, it seems like it is working, but when I scope the SDIO line I don't see any activity.  It is almost like the SPI device (in microblaze) is in loopback mode (which is an option) even though I haven't set it.  Can anyone spot my (most probably) sill mistake?  Thanks in advance!
int main()
	int Status;
	u8 *BufferPtr;
	u8 UniqueValue;
	int Count;
	int Page;
	u8 Buffer[10];
	XSpi_Config *ConfigPtr;	/* Pointer to Configuration data */
   Xil_ICacheEnable();
   Xil_DCacheEnable();
   print("---Entering main---\n\r");
	 * Initialize the SPI driver so that it is  ready to use.
	ConfigPtr = XSpi_LookupConfig(SPI_DEVICE_ID);
	if (ConfigPtr == NULL) {
		return XST_DEVICE_NOT_FOUND;
	Status = XSpi_CfgInitialize(&Spi, ConfigPtr,
				  ConfigPtr->BaseAddress);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * Set the SPI device as a master and in manual slave select mode such
	 * that the slave select signal does not toggle for every byte of a
	 * transfer, this must be done before the slave select is set
	Status = XSpi_SetOptions(&Spi, XSP_MASTER_OPTION | XSP_MANUAL_SSELECT_OPTION);
		return XST_FAILURE;
	 * Select the slave on the SPI bus, the EEPROM device so that it can be
	 * read and written using the SPI bus
	Status = XSpi_SetSlaveSelect(&Spi, SEEPROM_SPI_SELECT);
		return XST_FAILURE;
	 * Start the SPI driver so that interrupts and the device are enabled
	XSpi_Start(&Spi);
	XSpi_IntrGlobalDisable(&Spi);
	Buffer[0] = 0x81;
	XSpi_WriteReg(&Spi.BaseAddr, 0x00, 0x81);
	Buffer[0] = XSpi_ReadReg(&Spi.BaseAddr, 0x00);
	xil_printf("Buffer[0] = 0x%x\r\n", (u8)Buffer[0]);
   print("---Exiting main---\n\r");
   Xil_DCacheDisable();
   Xil_ICacheDisable();
   return 0;
can u say exactly what errors are u getting. I have run the code in my system, except some small errors like declaring spi and spi_ device it is working fine.
regards,
yagnik
Voyager
Voyager
yagnik,
Thanks for taking a look at it for me.  I actually am not getting an error, it just isn't working.  I can poke a value into a register and then read the value back, but I am not actually seeing anything going to/from the SPI device (for isntance I don't see CS or SDIO move at all during transfer).  I was convinced it was something in my code, but now I am starting to wonder if it is something lower (like in the XPS design).  Besides telling XPS that I have SPI, do I need to do anything else to set it up?  I left the memory mapping and all of that howeer XPS wanted to set it up.
Thanks a ton!!!
Even if you have left memory and io mapping to XPS I think it's not a problem. You can just declare your spi device like
XSpi my_spi;
And define device_ID  like
#define SPI_DEVICE_ID       XPAR_SPI_0_DEVICE_ID
It might help you.
regards
yagnik
Voyager
Voyager
OK, thanks.  I do have that (I should have included my #defines for completeness).  When I have run selftests it seems to pass...
Here are some screenshots of my XPS setup (in case something is obviously wrong):
the bus interface in XPS
The port view in XPS
Address view in XPS
From the MHS in XPS
Also from the MHS
your XPS connections and HMS files looks fine(check if your clock input is differential ?). As you said earlier that there is no activity on SDIO, you can check the UCF file(pins allotted to nets) is correct or not .
regards,
yagnik
Voyager
Voyager
The clock input to the microblaze is differential (not sure why the XPS does that, but I haven't found a way to stop it).  I know the module is running fine because the serial JTAG print statements are coming through fine and I can blink an LED when I press a push button.
I believe the UCF is fine, and this morning I even routed the MISO, MOSI, CLK, and CS to 4 unused pins on a header and I still don't get any toggling on either the CLK or the CS.  I am starting to run out of things to question...
I am too running out of probable problem areas. So have you found out what the problem was ? If you have, then do share with us.
Good day,
Yagnik
Voyager
Voyager
Nope, still having issues.  I can manually control the lines via Verilog, but trying to use them for SPI in microblaze is still not working...
Voyager
Voyager
Well, I finally got things working, so I thought I would leave it here in case someone else could find it useful.
Here are some of the things i did and in the end it is working:
1 - Upgraded to 14.1 from 13.4 (don't know that it is a requirement, but I will stay working up here)
2 - Leave the SPI ports in the MHS file as IO instead of making them just I or O as I show in the images above
3 - In the Verilog code, make the SPI pins inout ports and connect them directly to the microblaze module (do not put a wire inbetween)
4 - Here is my code I used (key difference is the fact that readReg and writeReg I originally was trying to use is for reading/writing the FPGA spi device (and its low-level support), it can be made to work, but it is easier to use the transfer function:
#include <stdio.h>
#include <stdlib.h>
#include "xparameters.h"
#include "xil_cache.h"
#include "xspi.h"
#include "spi_header.h"
#include "xbasic_types.h"
#define SPI_SELECT 0x01
#define LED_CHANNEL 1
int main()
	static XSpi Spi;
	int Status;
	u8 WriteBuffer[10];
	u8 ReadBuffer[10];
	Xil_ICacheEnable();
	Xil_DCacheEnable();
	xil_printf("---Entering main---\n\r");
	 // Initialize the SPI driver so that it is  ready to use.
	Status = XSpi_CfgInitialize(&Spi, ConfigPtr,ConfigPtr->BaseAddress);
	if (Status == XST_SUCCESS)
    		xil_printf("Spi Initialize success!\n\r");
   	else
    		xil_printf("Spi Initialize failed!\n\r");
	 // Set the SPI device as a master and in manual slave select mode such
	 // that the slave select signal does not toggle for every byte of a
	 // transfer, this must be done before the slave select is set
		return XST_FAILURE;
	// Select the slave on the SPI bus so that it can be
	// read and written using the SPI bus
	XSpi_GetSlaveSelect(&Spi);
	Status = XSpi_SetSlaveSelect(&Spi, SPI_SELECT);
		return XST_FAILURE;
	// Start the SPI driver so that interrupts and the device are enabled
	Status = XSpi_Start(&Spi);
		return XST_FAILURE;
	//disable global interrupts since we will use a polled approach
	//Out ADC is setup to use the same pin (SDIO/MOSI) for both TX and RX, so we
	//need to turn the ADC from 2-wire to 3-wire (uses the SDO as a MISO)
	//We do this by setting the "write" bit as well as the upper bits of the address
	//to 0, and the rest of the address to 0, then we write the value 0x99 to that
	//address (see datasheet for part)
	WriteBuffer[0] = 0x00;
	WriteBuffer[1] = 0x00;
	WriteBuffer[2] = 0x99;
	Status = XSpi_Transfer(&Spi, WriteBuffer, ReadBuffer, 3);
		return XST_FAILURE;
	//Now I will do a read of the 0x08 register to make sure I can read the chip ID
	//for this part. I set the "read" bit to 1 and the upper address bits to 0 and
	//the lower bits to 8. We have to tell the function to run for a 3 byte to make
	//sure the clock runs long enough for the read. The read value will be stored
	//in ReadBuffer[2]
	WriteBuffer[0] = 0x80;
	WriteBuffer[1] = 0x08;
	Buffer[0] = ReadBuffer[2];
		return XST_FAILURE;
	xil_printf("Buffer[2] = 0x%x\r\n", Buffer[2]);
	xil_printf("---Exiting main---\n\r");
	return 0;
And now everything is golden for me (for now).
Hey,  good job.
I was also able to run the code. But in my case I think it was more of a software problem. Using right functions was the issue,  is what I think.
I too have used transfer function.
Cheers...
i'm using actualy a Microblase with the spi interface, i try to add the spi Ip core in the microblaze but i have  this warning:
WARNING:EDK:2137 - Peripheral xps_spi_0 is not accessible from any processor in the system. Check Bus Interface connections and address parameters. and i also I noticed the the spi core is connected to the PLB bus and not to the AXI. i try to build another system but still the same problem. can anyone help me to build my project.
hi billel
if you are trying to create a AXI sub-system then axi_quadspi should be used. since you are trying to connect xps_spi, the tool is not able to find PLB bus. so if you are using AXI interface, try configuring a AXI Quad SPI in standard mode.
for new queries it is recommended to create a new post.
--hem
Mentor
Mentor
I know it's been a long time since you posted this thread. I have the same problem, I see no signaling on any of SPI pins. I modified my code to be exactly like what you implied as a successful one which is working properly. I did not made any changes on hardware and this happend suddenly after some software modifications!.
I am using EDK14.7
Any idea on this?
I would really appreciate it.
Hossein
i am new person on zynq soc , I am using spi0 for data transfer but i really don't know the commands through which i will trasnfer data and recive data to pl through spi. cuould you please help me.
Voyager
Voyager
When using AXI quad SPI IP as slave, what modification come into your code? Any hint?
