Can't get ZCU102 USB 3.0 port working in device mode with bare-metal
I am struggling to get the USB 3.0 port working on the ZCU102.  Everything seems to be in place in terms of the jumpers, the design in Vivado and the software.  However, I never see any USB messages on USB sniffer (Beagle USB 480).  With the board connected to my PC (with or without the sniffer), I don’t even see the D+ or D- signals being pulled high on a scope.  The VBUS pin shows +5V as expected.
At this point, everything is based on a bare-metal “Hello, World” application running on the A53 and the hardware design, both straight out of UG1209 Embedded Design Tutorial.
Here is the I/O Configuration:
I also added the USB0 3.0 port to the Isolation Configuration as shown:
In the SDK, I then added the non-DFU files from the usbpsu example folder to the project as described at the ZynqMp USB Standalone Driver page here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842468/ZynqMp+USB+Stadalone+Driver
From inside the main() function in helloworld.c, I called the main function in xusb_intr_example.c.
int main()
    init_platform();
    print("Hello World\n\r");
    usb_storage_main();  // main() from xusb_intr_example.c
    cleanup_platform();
    return 0;
I am following the jumper settings for the device mode as shown in these pictures:
J7 = OFF
J113 = Pins 1-2
J110 = Pins 1-2
https://photos.app.goo.gl/D6ijZDzvNUe8EEds9
When I step through the code, I don’t see anything suspicious.  No error codes are returned.  However, there is no evidence that anything is happening on the FPGA (USB device) side.  Like I said, the D+/D- pins are both held low.  No interrupts are triggered.
I haven’t tried building the Linux app and running that yet, but that might be next step.
Does anyone have any ideas what could wrong or where to look?
Does anyone have a binary version I could try just to verify my board?
Thanks in advance,
Dave
@swdave
Please refer the jumper settings for "Peripheral Mode" at the Wiki page online -  https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842047/Zynq+Ultrascale+MPSoc+Standalone+USB+device+driver?searchSessionId=d4d3a034-6471-436c-9c0f-3ef3277f4f83
Attached 2018.3 binaries for SDCARD ro boot my generated files for USB mass storage. Let me know if this works on your ZCU102 board or not?
@jadhavs ,
Thank you so much for your reply and helpful image.
I booted your images from the SD card.  Windows detected a device on the bus and tried to enumerate it, but it could not complete the process.  It said it could not load the driver for the mass storage device and I get an "Unknown Device" in my Windows Device Manager.
When I put the Beagle USB sniffer in the system, I saw what looked like good USB messages between the Xilinx and the PC.
A couple of questions:
- Is this image configured for USB3.0?  If so, do I need a USB3.0 cable for it to work?
- What type of connector do you recommend I use on the cable one the Xilinx end(micro-B, micro-AB)?
(I have production silicon.)
Before I saw your message, I was able to achieve similar results by using the FSBL built with standard HW image for the ZCU102 and then an ELF file I created using the mass storage code.  I am working on getting the same to work with my own HW image.
UPDATE: I got it to work using your boot image. Windows was able to format the drive and it showed up in Explorer.
I built my own boot image with the FSBL from the embedded tutorial, the PMU from the tutorial and the usb mass storage test application.  I am very close.  Everything is running and Windows shows the "Mass Storage Device" in the Device Manager.  However, I do not get prompted to format the device and it does not show up as a drive in Windows Explorer.
Does that make any sense to you?  I attached the log with CH9_DEBUG enabled in the USB example code.
Thanks a ton!
Actually, I spoke a little too soon.  I was able to format the drive, but then any time I tried to access the newly formatted device, Explorer crashed.
Q1: Any thoughts about why I can't actually use the formatted device?
In any case, you got me going in the right direction.  So, I started with a clean Vivado build based on the ZCU102.  I then used the SDK to create an FSBL for the R5.  That all works fine. Then, I created an app I called usb_test, which is again the mass storage device code compiled into an ELF file.  If I run the FSBL using the debugger and then download my usb_test.elf file using XSCT (with "dow" command), I see the USB messages going back and forth.  However, if I don't use the FSBL at all and just use the debugger to run my usb_test.elf code, the program runs, but no interrupts/messages are seen.
Q2: What is the FSBL doing that I need in order to get the USB to work?
Thanks in advance,
Dave ...
Hi jadhavs,
I have test your image and that works.  Thanks.
Can you share the fpga project with us?  I want to merge in our custom features into it.
Henry
