dinaemadeldin
Can't import required packages when using axi_vip
I try to verify my custom AXI_IP using AXI VIP as AXI4_Lite master , when I try to import the required packages <component_name>_pkg and axi_vip_pkg error appears in vivado as those packages aren't declared
Can any one help me ?
Tags (3)
florentw
Hi @dinaemadeldin
This is usually only during the syntax checker phase that vivado has some issue finding those files. If the names are correct and you run simulation then simulation will probably happen properly.
Most of the time you can ignore the fact that the syntax checker is saying that the files for the VIP are not found
Florent
florentw
Hi @dinaemadeldin
Florent
