Cannot program FPGA
Hi! can someone help me? I'm trying to program FPGA on MicroZed board but suddenly I keep getting this error and it won't do any FPGA programing on any project:
Program FPGA failed
  Cannot write to target
    Cannot flush JTAG buffers
    Error Address = 0xf8000900, Size = 0x00000004
please someone help me, I need the MicroZed to work for my final project and deadline is close :(
Do a stop before rst then.
Check the following ar to set the environment variable
http://www.xilinx.com/support/answers/11630.html
Try the following:
1. Open XMD console and typ the following commands:
connect arm hw
rst
exit
2. Set the environment variable XIL_CSE_ZYNQ_SKIP_RESET=1
Now re-program the fpga.
What result from running the command is attached in this post.
Also, how do I Set the environment variable?
Can this thing is resulted from hardware failure?
It also can't be stopped, it says: Unable to stop Processor. System could be in unknown state. Please reset the system.
and changing the environmental variable isn't working either.
I think the problem is xilinx jtag programmer is broken, the other day I was misplaced the pin by 1 slot and accidentally plug the Vcc pin to the Ground Port. But, Thanks though for the help, I appreciate it :)
no. if there is some device detected on JTAG at al, then cable as such is working ok.
xilinx znyq jtag is badly badly designed, there are so many cases where the jtag tools fail from unknown reason.
try rst stop multiply times, sometimes you get lucky.
erase spi flash, select pure jtag boot mode, etc..
in some cases when bootrom does fallback search it may disable JTAG for time as long as 15 seconds, the tools will never wait that long.
After I'm getting my new JTAG programmer, the error has changed, It now says:
Program FPGA failed
  Failed to download the bit file
    Failed to verify DONE bit after configuring FPGA
and the XMD console now can properly do rst and stop command, but the FPGA still can't be programmed.
I'm using dilligent JTAG-HS 3 Rev.A
Are you able to program the board using Vivado or using iMPACT?
how do I program the board using vivado?
After testing to program the board using Diligient usb-jtag rev G that I borrow from my friend, the board can be programmed succesfully on SDK, but it won't work on my jtag-hs 3 rev A that I just buy, what is wrong with the downloader? is the downloader is a defect item?
HS3 has an extra feature for soft reset on separate pin. but if you connect only jtag pins it should not matter
