ejleiss
Change SPI clock Frequency
I found the following VHDL code for an SPI master online.  I would like to slow down the SPI clock frequency, but it seems it is tied to my FPGA clock.  How could I modify this code to easily change the SPI clock frequency?
Thank you for the assistance.. The code is attached.
Tags (2)
venui
May i know which device and IP are you using.
Venu
bhall0107
Hi @ejleiss
That code definitely takes the system clock in from whatever you connect to it (probably the FPGA clock you're referencing). You could try using a clock divider to lower the frequency and then provide it to this code. Or you could even add the clock divider in this component. I can't make any promises regarding the efficiency of the code in the link I sent, but at least you can see an idea.
Hope that helps,
Brad
