Change plb IPIF to AXI IPIF
i have a ZedBoard and try to migrate a core from PLB (used on an other board) to AXI using EDK 14.6
The PLB slave used a PLB IPIF.
My idea is to exchange the plb IPIF with a AXI-Lite IPIF, and leave the actual logic untouched.
Therefore, i created an AXI-Lite Slave with CIP and edited all relevant files.
But, something seems to be wrong. I can read the Slave register, but user logic doesn't work.
I have no idea why. What is the problem?
User Logic:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library proc_common_v3_00_a;
use proc_common_v3_00_a.proc_common_pkg.all;
entity user_logic is
  generic
    C_NUM_REG                      : integer              := 1;
    C_SLV_DWIDTH                   : integer              := 32
  port
    Bus2IP_Clk                     : in  std_logic;
    Bus2IP_Resetn                  : in  std_logic;
    Bus2IP_Data                    : in  std_logic_vector(C_SLV_DWIDTH-1 downto 0);
    Bus2IP_BE                      : in  std_logic_vector(C_SLV_DWIDTH/8-1 downto 0);
    Bus2IP_RdCE                    : in  std_logic_vector(C_NUM_REG-1 downto 0);
    Bus2IP_WrCE                    : in  std_logic_vector(C_NUM_REG-1 downto 0);
    IP2Bus_Data                    : out std_logic_vector(C_SLV_DWIDTH-1 downto 0);
    IP2Bus_RdAck                   : out std_logic;
    IP2Bus_WrAck                   : out std_logic;
    IP2Bus_Error                   : out std_logic
end entity user_logic;
architecture IMP of user_logic is
  --USER signal declarations added here, as needed for user logic
	component prng_lfsr is
    Port ( clk   : in  STD_LOGIC;
           rst   : in  STD_LOGIC;
           prn   : out  STD_LOGIC_VECTOR (31 downto 0);
           ready : out  STD_LOGIC;
           nxt   : in  STD_LOGIC);
	end component;
  -- Signals for user logic slave model s/w accessible register example
  signal slv_reg_write_sel              : std_logic_vector(0 to 0);
  signal slv_reg_read_sel               : std_logic_vector(0 to 0);
  signal slv_ip2bus_data                : std_logic_vector(0 to C_SLV_DWIDTH-1);
  signal slv_read_ack                   : std_logic;
  signal slv_write_ack                  : std_logic;
  signal prng_prn						: std_logic_vector(31 downto 0);
  signal prng_ready						: std_logic;
  signal prng_nxt						: std_logic;
begin
  --USER logic implementation added here
	prng_lfsr_inst : prng_lfsr port map(
		clk   => Bus2IP_Clk,
		rst   => Bus2IP_Resetn,
		prn   => prng_prn,
		ready => prng_ready,
		nxt   => prng_nxt
  slv_reg_read_sel  <= Bus2IP_RdCE(0 downto 0);
  slv_read_ack      <= Bus2IP_RdCE(0);
  -- implement slave model software accessible register(s) read mux
  SLAVE_REG_READ_PROC : process( slv_reg_read_sel ) is
  begin
    case slv_reg_read_sel is
      when "1" => slv_ip2bus_data <= prng_prn;
      when others => slv_ip2bus_data <= (others => '0');
    end case;
  end process SLAVE_REG_READ_PROC;
  IP2Bus_Data  <= slv_ip2bus_data when slv_read_ack = '1' else
                  (others => '0');
  IP2Bus_WrAck <= '0';
  IP2Bus_RdAck <= slv_read_ack and prng_ready;
  IP2Bus_Error <= '0';
	prng_nxt <= slv_read_ack;
end IMP;
PAO
lib proc_common_v3_00_a  all
lib axi_lite_ipif_v1_01_a  all
lib prng_v1_00_b prng_lfsr vhdl
lib prng_v1_00_b user_logic vhdl
lib prng_v1_00_b prng vhdl
 MPD
BEGIN prng
## Peripheral Options
OPTION IPTYPE = PERIPHERAL
OPTION IMP_NETLIST = TRUE
OPTION HDL = VHDL
OPTION IP_GROUP = MICROBLAZE:USER
OPTION DESC = PRNG
OPTION LONG_DESC = AXI-Lite Interface
OPTION ARCH_SUPPORT_MAP = (others=DEVELOPMENT)
## Bus Interfaces
BUS_INTERFACE BUS = S_AXI, BUS_STD = AXI, BUS_TYPE = SLAVE
## Generics for VHDL or Parameters for Verilog
PARAMETER C_S_AXI_DATA_WIDTH = 32, DT = INTEGER, BUS = S_AXI, ASSIGNMENT = CONSTANT
PARAMETER C_S_AXI_ADDR_WIDTH = 32, DT = INTEGER, BUS = S_AXI, ASSIGNMENT = CONSTANT
PARAMETER C_S_AXI_MIN_SIZE = 0x000001ff, DT = std_logic_vector, BUS = S_AXI
PARAMETER C_USE_WSTRB = 0, DT = INTEGER
PARAMETER C_DPHASE_TIMEOUT = 8, DT = INTEGER
PARAMETER C_BASEADDR = 0xffffffff, DT = std_logic_vector, MIN_SIZE = 0x100, PAIR = C_HIGHADDR, ADDRESS = BASE, BUS = S_AXI
PARAMETER C_HIGHADDR = 0x00000000, DT = std_logic_vector, PAIR = C_BASEADDR, ADDRESS = HIGH, BUS = S_AXI
PARAMETER C_FAMILY = virtex6, DT = STRING
PARAMETER C_NUM_REG = 1, DT = INTEGER
PARAMETER C_NUM_MEM = 1, DT = INTEGER
PARAMETER C_SLV_AWIDTH = 32, DT = INTEGER
PARAMETER C_SLV_DWIDTH = 32, DT = INTEGER
PARAMETER C_S_AXI_PROTOCOL = AXI4LITE, TYPE = NON_HDL, ASSIGNMENT = CONSTANT, DT = STRING, BUS = S_AXI
## Ports
PORT S_AXI_ACLK = "", DIR = I, SIGIS = CLK, BUS = S_AXI
PORT S_AXI_ARESETN = ARESETN, DIR = I, SIGIS = RST, BUS = S_AXI
PORT S_AXI_AWADDR = AWADDR, DIR = I, VEC = [(C_S_AXI_ADDR_WIDTH-1):0], ENDIAN = LITTLE, BUS = S_AXI
PORT S_AXI_AWVALID = AWVALID, DIR = I, BUS = S_AXI
PORT S_AXI_WDATA = WDATA, DIR = I, VEC = [(C_S_AXI_DATA_WIDTH-1):0], ENDIAN = LITTLE, BUS = S_AXI
PORT S_AXI_WSTRB = WSTRB, DIR = I, VEC = [((C_S_AXI_DATA_WIDTH/8)-1):0], ENDIAN = LITTLE, BUS = S_AXI
PORT S_AXI_WVALID = WVALID, DIR = I, BUS = S_AXI
PORT S_AXI_BREADY = BREADY, DIR = I, BUS = S_AXI
PORT S_AXI_ARADDR = ARADDR, DIR = I, VEC = [(C_S_AXI_ADDR_WIDTH-1):0], ENDIAN = LITTLE, BUS = S_AXI
PORT S_AXI_ARVALID = ARVALID, DIR = I, BUS = S_AXI
PORT S_AXI_RREADY = RREADY, DIR = I, BUS = S_AXI
PORT S_AXI_ARREADY = ARREADY, DIR = O, BUS = S_AXI
PORT S_AXI_RDATA = RDATA, DIR = O, VEC = [(C_S_AXI_DATA_WIDTH-1):0], ENDIAN = LITTLE, BUS = S_AXI
PORT S_AXI_RRESP = RRESP, DIR = O, VEC = [1:0], BUS = S_AXI
PORT S_AXI_RVALID = RVALID, DIR = O, BUS = S_AXI
PORT S_AXI_WREADY = WREADY, DIR = O, BUS = S_AXI
PORT S_AXI_BRESP = BRESP, DIR = O, VEC = [1:0], BUS = S_AXI
PORT S_AXI_BVALID = BVALID, DIR = O, BUS = S_AXI
PORT S_AXI_AWREADY = AWREADY, DIR = O, BUS = S_AXI
END
you have to edit the MPD File also.
you have to add the ports which are output ports, if you want to make them available for other modules in the system.
