Changing the values of DDRC Module register in psu_init
I am working on the ZCU102 board. In the Zynq Ultrascale+ PS IP of block design, I am using the default DDR settings. However, these settings do not contain information about how the DDR scheduler or controller works. In Xilinx SDK, the psu_init.c file contains all the default values that are in the DDRC Module registers. How do I change these default values? Can I modify the psu_init.c file and psu_init.tcl file? What steps do I need to take care of in order to achieve this? For example, in UG 1087, I need to change the default of register SCHED at location 0xFD070254 from 0x0 to 0x20.
Any help is appreciated.
Tags (2)
I'm also trying to customize DDRC Module register in psu_init. However, I'm not very clear for the PSU_Mask_Write function. If you already have the experiences, could you help me for this?
