Clock with the frequency same as Zynq Processor frequency
Can I generate a clock running with the same frequency as that of the Zynq processor.?
I am using ZYNQ zc702 evaluation board and my task is to check whether the processor is really running at the frequency that I have input using vivado.
Thank you.
watari
Hi www.afroz62@gmail.com
What do you mean "Clock with the frequency same as Zynq Processor frequency" ?
1. You'd like to generate same clock frequency by something.
2. You'd like to make sure whether the clock is alive or not. Include clock frequency.
3. Other
If 1, you can generate it by PLL or MMCM.
If 2, you can observe clock frequency by measurement of clock frequency module.
Best regards,
Hi, watari
Its 1.
Thank you for the reply.
I want to generate a clock with same frequency as that of the zynq processor. Can you please, give me the details of the process.?
watari
Would you use Clocking Wizard IP on Vivado ?
https://www.xilinx.com/support/documentation/ip_documentation/clk_wiz/v6_0/pg065-clk-wiz.pdf
Best regards,
bfrazier_arete
Where do you plan on using the clock?  In the PL?
I don't want to input any frequency. The program should identify the processor frequency and run accordingly.
watari
Do you want to generate clock by program ?
If yes, would you refer page 699 on the following URL ?
https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
Best regards,
Here is what I am exactly working on:(I am sorry to deviate from current topic)
I have to run an infinite while loop and check the output on oscilloscope. As I change the processor frequency, I will get a change in the period of output square wave time-period, right.?
And that is what I have to achieve. Please help me with this.
Following is the code that I have written:
module validation(
output a
reg a1 = 0;
assign a = a1;
integer counter = 0;
while(1) // Infinite While Loop
begin
counter <= counter + 1; //The counter goes up.
if(counter == 0)begin
a1 <= ~a1; //If the counter reaches 1000, toggle the output.
counter <= 1000; // Resetting the counter.
end
end
endmodule
But I am not able to run it.
Yes, I am planning to use the clock in the PL.
watari
I'm sure that your concept is correct. But your code is bad. It's like c-language style. Not HDL.
Would you make sure your code by ex. lint tool ?
Best regards,
I am sorry, I dont have that tool.
watari
module validation(
// input clk,
output a
reg a1 = 0;
assign a = a1;
always @(1)
end
else
//end
endmodule
How about this code?
The Report shows no violations. But I am not able to generate bitstream.
bfrazier_arete
This won't work due to sampling theory. You would never now what your frequency is just using the clock as your counting source. To do a counting model for estimating frequency of a clock you must have another clock that is equal to or faster in frequency to the clock you are measuring.
bfrazier_arete
Why don't you read the registers of the Zynq PS instead of trying to measure the frequency? The TRM outlines how the clocks are generated from the available PLLs in the processor. If you just read the settings of the registers, you can determine if the processor clock source is setup correctly? The PLLs are setup from scripts built into your boot image in the first place. If you independently read the registers, it should tell you everything you need to know.
