manuelstahl
Combination of traffic_gen and axi_dma for AXI stream
I made a simple test design using the AXI Traffic Generator and the AXI DMA. What I observed is:
- without FIFO between both, the Traffic Generator seems to not send any data (the "Done" bit in the "Streaming Control" register never gets set and the TLSTCNT register stays 0) and the DMA generates a timeout
- using a FIFO between both (see attached BD), the Traffic Generator seems to work, but DMA still generates a timeout
Still what I can observe is that the content in the DMA buffer changes after the transfer attempt.
Any idea why the DMA does not start to transfer data?
Tags (3)
