fecon001
Configuration file for Quad-SPI Memory on ZC702
Hey,
I'd like to use the Quad-SPI Flash Memory on the ZC702 Evaluation Board to save my configuration.
Generate my bitstream is no problem. But if i try to create my configuration file(.mcs file) with:
write_cfgmem -format mcs -interface spix4 -size 128 -loadbit "up 0x0 N:/test.bit" -file design.mcs
Following Error occurs:
ERROR: [Writecfgmem 68-20] SPI_BUSWIDTH property is set to "1" on bitfile N:/test.bit. This property has to be set to "4" to generate a configuration memory file for the SPIX4 interface. Please ensure that a valid value has been set for the property BITSTREAM.Config.SPI_buswidth and rerun this command.
If i try change the SPI Bus width with:
set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [current_design]
it says:
ERROR: [Netlist 29-177] Cannot set property 'BITSTREAM.CONFIG.SPI_BUSWIDTH' because the property does not exist.
I read a few posts about this and found out that there isn't such an property on the zc702.
So my question is: How to create an configuration file that is possible to use with the Quad SPI Memory for configuration after startup???
I'm using Vivado 2016.2.
sameer120
I am having similar issue on PicoZed Board , can any body provide solution for this.
I am using Vivado 2018.3 Version and PicoZeb Board with 7030 part Rev C.
Thansk
Sameer
abommera
Hi @sameer120 ,
In Zynq, you should create a boot image using SDK whch contains FSBL and bit file. The FSBL is used to initialise the PS and defines the partions of boot image. Please try with SDK to create the boot image. Please let me know if you have any queries.
Thanks & Regards
Anil B
