04-24-2019 09:07 AM
Hi guys,
I'm using a Xilinx ZYNQ device equipped with the help of FreeRTOS port.
The final application will be used in the context of electric motor control so, in order to reduce control-law interrupt latency, I've registered the related handler with a priority that exceeds configMAX_API_CALL_INTERRUPT_PRIORITY.
Given the previous settings, the interrupt is properly triggered also under FreeRTOS critical sections - exactly as I expected to.
Now, I intend to share data between application tasks and the aforementioned interrupt handler.
To avoid race condition I intend to mask cpu interrupts, write the data, and then re-enable cpu interrupts.
Something like in the example reported below.
Is this possible /is there a better way to do it?
Does it interfere with FreeRTOS itself leading to system failure?
static uint32_t EM_PositionReferece = 0u; /* run in the context of the task */ void EM_SetPositionReference(UINT32 user) { /* mask CPU interrupt */ __asm volatile ( "CPSID i"); __asm volatile ( "DSB" ); __asm volatile ( "ISB" ); /* set motor-control position reference to be used in interrupt */ EM_PositionReferece = user; /* * NO FreeRTOS API usage here! */ /* un-mask CPU interrupt */ __asm volatile ( "CPSIE i"); __asm volatile ( "DSB" ); __asm volatile ( "ISB" ); } void PL_IRQHandler(void) { ControlLaw_Exec(EM_PositionReferece ); /* * NO FreeRTOS API usage here! */ }
As last thing, in the previous example the interrupt are fully masked and then unmasked.
Is there a way (e.g. a dedicated CPU instruction) to get interrupt masking status and simultaneously disabling them?
What I want to achieve is something like the line below
/* mask interrupt and get previous masking status */ irqMask = _MaskIRQ(); /* * set motor-control variable shared with IRQ */ /* restore interrupt masking status read at _MaskIRQ */ _RestoreIRQ(irqMask);
Thanks in advance,
Bucky
04-24-2019 11:39 AM
Replied here https://sourceforge.net/p/freertos/discussion/382005/thread/4e4767a000/
