Anonymous
Not applicable
Create device tree Error
Hi, when I try to use device tree generator i get the following error: 23:17:03 INFO : Processing command line option -hwspec E:/Proj/Proj/Proj_2014_4/Proj_2014_4.sdk/Proj.hdf. 23:17:09 INFO : Launching XSDB server: xsdb.bat -s D:/Xilinx/SDK/2014.4/scripts/xsdb/xsdb/xsdb-server.tcl 2450 23:18:54 INFO : Saving repository preferences. 23:18:54 INFO : Reading in cores from local repositories: E:\Proj\Proj\Proj_2014_4\device-tree-xlnx-xilinx-v2014.4 23:18:54 INFO : Cleaning BSP projects in the workspace. 23:18:55 INFO : Saving repository preferences. 23:20:44 INFO : 'device_tree' is a board support package for an OS for which applications cannot be developed within SDK. 23:20:44 INFO : You can configure and build project 'device_tree_bsp_0' within SDK at will, but have to export it into the appropriate third party environment to develop applications. 23:20:46 ERROR : [Hsi 55-1545] Problem running tcl command ::sw_cpu_cortexa9::generate : no files matched glob pattern "E:\Proj\Proj\Proj_2014_4\device-tree-xlnx-xilinx-v2014.4\device_tree/data/kernel_dtsi/2014.4/*" while executing "glob [get_property "REPOSITORY" $i]/data/kernel_dtsi/${kernel_ver}/*" ("foreach" body line 4) invoked from within "foreach i [get_sw_cores device_tree] { set kernel_dtsi "[get_property "REPOSITORY" $i]/data/kernel_dtsi/${kernel_ver}/${zynq_7000_fname}" if {[fil..." (procedure "create_dt_tree_from_dts_file" line 5) invoked from within "create_dt_tree_from_dts_file" (procedure "gen_root_node" line 7) invoked from within "gen_root_node $drv_handle" invoked from within "set master_root_node [gen_root_node $drv_handle]" (procedure "::sw_cpu_cortexa9::generate" line 1) invoked from within "::sw_cpu_cortexa9::generate ps7_cortexa9_0" [Hsi 55-1442] Error(s) while running TCL procedure generate() 23:20:46 ERROR : Failed to generate BSP. 23:20:46 INFO : BSP Project P/device_tree_bsp_0 has been successfully migrated. 23:20:48 ERROR : [Hsi 55-1545] Problem running tcl command ::sw_cpu_cortexa9::generate : no files matched glob pattern "E:\Proj\Proj\Proj_2014_4\device-tree-xlnx-xilinx-v2014.4\device_tree/data/kernel_dtsi/2014.4/*" while executing "glob [get_property "REPOSITORY" $i]/data/kernel_dtsi/${kernel_ver}/*" ("foreach" body line 4) invoked from within "foreach i [get_sw_cores device_tree] { set kernel_dtsi "[get_property "REPOSITORY" $i]/data/kernel_dtsi/${kernel_ver}/${zynq_7000_fname}" if {[fil..." (procedure "create_dt_tree_from_dts_file" line 5) invoked from within "create_dt_tree_from_dts_file" (procedure "gen_root_node" line 7) invoked from within "gen_root_node $drv_handle" invoked from within "set master_root_node [gen_root_node $drv_handle]" (procedure "::sw_cpu_cortexa9::generate" line 1) invoked from within "::sw_cpu_cortexa9::generate ps7_cortexa9_0" [Hsi 55-1442] Error(s) while running TCL procedure generate() 23:20:48 ERROR : Error generating bsp sources: Failed to generate BSP. 23:20:48 ERROR : Failed to generate sources for BSP project device_tree_bsp_0 org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details. at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Please check if below discussion helps
http://forums.xilinx.com/t5/Embedded-Linux/device-tree-generate-error/td-p/482308
Ashish
as per Xilinx on twitter petalinux 2014.4 should be released 2 dec,
try the petalinux devicetree generator, if that fails then open a webcase.
Any update on this? I am getting the same error when trying to generate the device tree.
Cheers
Raul
Would that be possible to share the xml/hdf ? Also which OS are you trying to use to generate the dts?
--Hem
