01-06-2013 09:20 PM
I am building a multi-core design where I plan to pull out several Read-only signals from the top-level of the PCORE and collect them into another core (something like a Trace Port in Microblaze).
I was looking to see if anyone has had luck building a custom bus type in MPD file so that these signals (there are some 15 different names) could be aggregated as a bus ? Or will I have to move them around the MHS level as vectors only ?
Boffin
01-07-2013 11:58 AM
You would do something like:
BUS_INTERFACE BUS = S_WRQUEUE0 , BUS_STD = WRQUEUE, BUS_TYPE = TARGET
PORT WRDMA0_VALID = IDVALID , BUS = S_WRQUEUE0, DIR = I
PORT WRDMA0_READY = IDREADY , BUS = S_WRQUEUE0, DIR = O
PORT WRDMA0_ADDR = ADATA , BUS = S_WRQUEUE0, DIR = O, VEC = [31:0]
An then on the other core that connects to the above, you would have
BUS_INTERFACE BUS = M_WRQUEUE0 , BUS_STD = WRQUEUE, BUS_TYPE = INITIATOR
PORT M_WRDMA_VALID = IDVALID , BUS = M_WRQUEUE0, DIR = O
PORT M_WRDMA_READY = IDREADY , BUS = M_WRQUEUE0, DIR = I
PORT M_WRDMA_ADDR = ADATA , BUS = M_WRQUEUE0, DIR = O, VEC = [31:0]
