stoned49th
Custom IP Read PFIFO Question
Hi, I'm quite new to FPGA's an heres my question on how to acces a Read PFIFO in an audio-input custom ip for the plb bus. I try to write two audio channels in one packet and acces it later in the software. I didn't have the time to test it yet, I just wantet you guys here to have a look at it, to see if I've done something substantially wrong. Heres the snippet from the user_logic.vhl:
Post_to_FIFO:process (Bus2IP_Clk) is
	variable status : integer range 0 to 20 := 0;
  begin
  	  if rising_edge(Bus2IP_Clk) then
	  		if (a_left_ready='1' and a_right_ready='1') then
				case status is
					when 0 =>
						IP2RFIFO_WrMark <= '1';
						status := status + 1;
					when 1 =>
						IP2RFIFO_WrMark <= '0';
						IP2RFIFO_WrReq <= '1';
						IP2RFIFO_Data <= audio_data_l;
					when 2 =>
						if (RFIFO2IP_WrAck='1') then
							IP2RFIFO_Data <= audio_data_r;
						end if;
					when 3 =>
							IP2RFIFO_WrReq <= '0';
							status := 0;
							a_left_ready := '0';
							a_right_ready := '0';
						end if;
				end case;
			else
			IP2RFIFO_Data <= "00000000000000000000000000000000";
			IP2RFIFO_WrRelease <= '0';
			IP2RFIFO_WrRestore <= '0';
			end if;
	  end if;
  end process Post_to_FIFO;
Lukas
