DDS configuration
hello experts
I am trying to creat the system showh in the figure below.
I have configured the DDS and i have also generated the signal as stated, but when i connect it to the clocl active pin i dont get the required signal on the oscilloscope.
am i going wong somewhere, any help would be appriciated.
Re: DDS configuration
I got it working.
I got it working.
