tatsuya1
DECERR is received
I'm using the AXI master I/F which generated in vivado. I've been tring to read some data from DDR3 memory by a physical address(ARPROT=3'd0).
When a AXI bus is observed using a logic analyzer(ILA) inside FPGA, DECERR is received.
I couldn't understand the reason why DECERR is received.
Conditions:
ZYNQ Processor is driven by Linux.
FPGA: XC7Z020-1CLG400I(Zynq-7000)
Vivado version: 2020.1
tatuya1
Tags (2)
tatsuya1
Thank you for your reply.
I'm sorry for lacking in information.
The block design is as follows.
A module named "vga_cnt_top" has an AXI master core. ILA is observing AXI bus between master and interconnect.
When the interconnect is replaced with a smartconnect, behavior changed a little, but smartconnect replies by DECERR.
In my environment, 1G byte memory is mounted. Threfore, it is accessible to the address from 0x00000000 to 0x3fffffff.
In case that the condition for "DECERR" reply is as follows, 2 and 3 aren't applicable I think.
1. Address decode error
2. non-secure transaction
3. FIXED type burst
refer to:
https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/AXI-Master-Decerr/m-p/804560#M20933
I don't know why the interconnect recognizes as "Address decode error".
Is there some setting of memory map or something?
By the way, the memory access is possible by an index from the environment of Vitis.
tatsuya1
tatsuya1
florentw
HI @tatsuya1
It might be good to have a view of your design and where you are adding the ILA.
For example, do you have an interconnect or smartconnect. Are you looking before or after the interconnect? Did you try to look on both side to see if this was coming from the interconnect?
Florent
tatsuya1
3. FIXED type burst
refer to:
tatsuya1
tatsuya1
tatsuya1
3. FIXED type burst
refer to:
tatsuya1
florentw
HI @tatsuya1
Can you share a screenshot of the address editor tab in vivado?
This is what defines the routing for the AXI transactions through the Interconnect/Smartconnect. If you did not define the address range accessible by your custom IP correctly you might get the DECERR
Florent
tatsuya1
Thank you for your quick reply.
The screen shot of "address editor" is the following.
For example, when AXI master of vga_cnt_top accesses a memory address of 0x3f800000-0x3f895fff(614k), how do I set it up?
florentw
HI @tatsuya1
Yes this would be the correct settings. Do you still get the DECERR with that?
Florent
tatsuya1
Unfortunately, AXI interconnect still replies by DECERR.
florentw
HI @tatsuya1
Did you re-generate the BD output products before running the simulation?
Florent
tatsuya1
Yes, I did.
Finally, my IP could access the memory space.
I think that there was misunderstanding in setting of "Address Editor".
Setting of address space my IP need to access as a "master", I should make it "include"(not exclude).
Is my understanding shown in following figure correct?
florentw
HI @tatsuya1
Yes this is correct you need to include the address space
Florent
tatsuya1
Hi, Florent-san
I appreciate your help so far.
I've chosen the best answer by mistake.
I'm sorry for that.
tatsuya1
