jacob15p
DMA Unable to transfer 64MB
My current project implements an AXI DMA in scatter-gather mode to transfer data between the Zynq processing system and a custom IP block. I'd like to be able to transfer the maximum of 64 MB at once, so I increased the DMA buffer length width to 26 bits, and increased memory allocation for the TX and RX buffers/BDs (I'm using the example code xaxidma_example_sg_poll.c). However, it seems the maximum amount of data I'm able to transfer at once is 1 MB; if I increase the DMA packet size beyond that the software simply crashes. Besides memory allocation, which I believe I have done correctly, I'm not sure what else could be causing this issue. Any ideas on what might be going wrong?
katsuki
Hi @jacob15p
If you change TX_BUFFER and RX_BUFFER to reserve 64MB, it probably will work.
Thank you.
Don't forget to Reply, Kudo, and Accept as Solution.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Hi @jacob15p
Thank you.
jacob15p
That fixed it! Thanks for the help
