habib81
DMA interruption using microblaze
hello,
I want to use an interrupt signal from DMA to microblaze (nexys 4 ddr board) . Unfortunately, I can't turn it on. Please wheres is the problem. Here is the program I'm using:
#include "xaxidma.h"
#include "xparameters.h"
#include "xdebug.h"
#include "xil_io.h"
#include <stdio.h>
#include "platform.h"
#include "xintc.h"
#define DMA_DEV_ID XPAR_AXIDMA_0_DEVICE_ID
#define MEM_BASE_ADDR (XPAR_MIG7SERIES_0_BASEADDR +0x0000000)
#define RX_BUFFER_BASE (MEM_BASE_ADDR + 0x00200000)
#define TX_BUFFER_BASE (MEM_BASE_ADDR + 0x00300000)
#define MAX_PKT_LEN_WORDS 1000
#define MAX_PKT_LEN MAX_PKT_LEN_WORDS*4
#define RX_INTR_ID XPAR_INTC_0_AXIDMA_0_S2MM_INTROUT_VEC_ID
#define TX_INTR_ID XPAR_INTC_0_AXIDMA_0_MM2S_INTROUT_VEC_ID
#define INTC_DEVICE_ID XPAR_INTC_0_DEVICE_ID
#define RESET_TIMEOUT_COUNTER 10000
static XAxiDma AxiDma;
static XAxiDma_Config *CfgPtr;
static XIntc Intc;
static void RxIntrHandler(void *Callback);
volatile int TxDone;
volatile int RxDone;
volatile int Error;
volatile u32 *TxBufferPtr;
volatile u32 *RxBuffeuart;
volatile u32 Value;
int main()
int state = 0;
CfgPtr = XAxiDma_LookupConfig(XPAR_AXIDMA_0_DEVICE_ID);
XAxiDma_CfgInitialize(&AxiDma, CfgPtr);
/* Set up Interrupt system */
XAxiDma_IntrEnable(&AxiDma, XAXIDMA_IRQ_ALL_MASK,XAXIDMA_DEVICE_TO_DMA);
/* Initialize the interrupt controller and connect the ISRs */
XIntc_Initialize(&Intc, INTC_DEVICE_ID);
XIntc_Connect(&Intc, RX_INTR_ID, (XInterruptHandler)RxIntrHandler, (void *)0);
//XIntc_Enable(IntcInstancePtr, TxIntrId);
XIntc_Enable(&Intc,RX_INTR_ID);
/* Start the interrupt controller */
XIntc_Start(&Intc, XIN_REAL_MODE);
TxBufferPtr = (u32 *)RX_BUFFER_BASE;
for(u32 i = 1; i < MAX_PKT_LEN+1; i ++) {
TxBufferPtr [i-1]= i;
while (1) {
switch (state) {
case(0):
XAxiDma_SimpleTransfer(&AxiDma,(u32)TxBufferPtr, MAX_PKT_LEN, XAXIDMA_DEVICE_TO_DMA);
state = 1;
break;
case(1):
break;
u32 IrqStatus;
int TimeOut;
XAxiDma *AxiDmaInst = (XAxiDma *)Callback;
/* Read pending interrupts */
IrqStatus = XAxiDma_IntrGetIrq(AxiDmaInst, XAXIDMA_DEVICE_TO_DMA);
/* Acknowledge pending interrupts */
XAxiDma_IntrAckIrq(AxiDmaInst, IrqStatus, XAXIDMA_DEVICE_TO_DMA);
* If no interrupt is asserted, we do not do anything
if (!(IrqStatus & XAXIDMA_IRQ_ALL_MASK)) {
return;
* If error interrupt is asserted, raise error flag, reset the
* hardware to recover from the error, and return with no further
* processing.
if ((IrqStatus & XAXIDMA_IRQ_ERROR_MASK)) {
Error = 1;
/* Reset could fail and hang
* NEED a way to handle this or do not call it??
XAxiDma_Reset(AxiDmaInst);
TimeOut = RESET_TIMEOUT_COUNTER;
while (TimeOut) {
if(XAxiDma_ResetIsDone(AxiDmaInst)) {
break;
TimeOut -= 1;
return;
* If completion interrupt is asserted, then set RxDone flag
if ((IrqStatus & XAXIDMA_IRQ_IOC_MASK)) {
for(u32 i = 1; i < MAX_PKT_LEN+1; i++) {
RxBuffeuart = TxBufferPtr + i - 1;
Value = Xil_In32((u32)RxBuffeuart);
xil_printf("%d\n",Value);
Tags (2)
