ruimachado
DMA on Petalinux
Hello everyone,
I am trying to implement a very simple test program to check the currect functioning of the DMA in Petalinux, but I am having some issues. I am using an FPGA from Enclustra and I already have their BSP.
I have the Petalinux image with the DMA proxy 2.0 driver. On the hardware side, I have the Xilinx DMA IP configured as follows (I attached the block diagram image as well):
- loop back
- scattered-gather mode
- interrupts enabled
I had included on the boot image the dma-proxy-test application and the petalinux image boots as expected.
I then proceed to do a modprobe on the dma-proxy driver. When I do this I receive the following messages on the console:
- [timestamp] DMA proxy module initialized
- [timestamp] (NULL Device *): DMA channel request error
- [timestamp] dma_proxy_driver: probe of dma_proxy failed with error -1
If I try to run the dma-proxy-test application I get the following error:
- Unable to open dma proxy device file
can anyone help me understand what might be wrong. I am following the tutorials on:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/1027702787/Linux+DMA+From+User+Space+2.0
Thanks in advanced
Tags (2)
