DMA standalone example AR# 57562
Hi all,
In the example AR# 57562, the correspondent attachment  does not use a simple counter to drive the S2MM channel of the AXI DMA as depicted in the diagram. Instead of that, there is a loop using a axis-data-fifo. Is there any design that really uses a counter or some kind of a sample source (with source HDL code) using a standalone application?
