Data Transfer From PL To PS
     I am new to this activity for data transfer from PL to PS, So can I know what are the possibilities to transfer data from PL to PS.
Re: Data Transfer From PL To PS
Use ports GP0, GP1 to receive data from PL of 1-4 bytes in size.
Use ports HP0-HP3 to receive data from PL bigger size.
There are special cores for transferring data between the PS and PL, for example Axi DMA.
Hi narendrandesainath@gmail.com,
From MPSoC devices, please check the "PS-PL AXI Interfaces" section of the UG1085 to get an idea about the available interfaces between PS and PL.
Figure 35-1 and Figure 35-2 are good diagrams that show these connections.
Best regards,
Abdallah
