Data transfer from PL to DDR memory
  On Zynq-7020, my aim is to transfer data from PL to DDR memory. For this I am using AXI Data Mover IP for PL to PS communication.
Always data is storing into OCM memory only, eventhough if I change the offset address in address editor. But I want to save these data in DDR memory. The BD I have attached, Please anybody can identify where I am doing mistake.
OR
If there is any best solution for this, Please suggest to me.
Hello @desai_
Is there any update?
Probably you need to give a proper CMD.
If the destination address is fixed by Address Editor, there is no flexibility to give the address by CMD.
Thank you
Ka2ki
Hello @desai_
You can get hints about DDR and OCM address mapping from another post how to write to DDR in Zynq from PL.
Thank you
Yoichi
Thank you for your valuable reply,
 Is it possible to write data directly from PL to DDR memory? without involiving ARM.
Hello @desai_
Yes it is.
UG1165 is a reference for read/write PS-DDR from PL using CDMA.
Thank you
Yoichi
This forum is based on the cooperation of everyone who participates.
Kindly note - Please mark the Answer as "Accept as solution" if information provided is helpful.
How, can you suggest to me to achieve this activity?
Yes it is.
And how does CDMA start without involving the PS (ARM)?
I think you could make use of the DataMover ip or you can access the AXI-bus directly.
Hello @desai_
I am not familiar with AXI Datamover.
May be, by giving a command from the CMD port, isn't the write destination address specified?
Thank you
Ka2ki
@katsuki,
   Even if did not give any command to CMD port, it works.
 But I unable to figure out, where destination address to be defined.
The CMD has a field Start Address (SADDR) where you specify where your data will be stored in memory.
When I change the address in CMD, which not effecting.  Its storing in default location I.e ox00000000
Hello @desai_
You may be able to verify by simulation that your command is either correct or not.
As far as I can see, if the address is correctly included in the CMD, the write address will be on the M_AXI_S2MM side.
If you want to try IP simulation, please refer to Ch5.Example Design of PG022.
Thank you
Ka2ki
Hello @desai_
Thank you
Ka2ki
The CMD_ready is always 0, it is not ready to accept the command values.
