robertwilliam
Difficulty in input connection (ISE/XPS 14.3 SP605)
I am learning XPS 14.3, on my SP605 board. The project is Xapp1026. It is found the first 4 connections format ETHERNET_dma are very strange. I don't know how it is entered. The 4 connections are the same contents. After the fourth entry is accidently removed, I cannot input the same content. In below picture, you can see in the second right pull-down menu there is no S_AXI etc. options, or AXI_STR_TXD_ARESETN.
Can you tell me how to enter the connection content?
