Anonymous
Not applicable
Discrepancy in port name
As per PG082 for PS7 IP there should be a port named ddr_bankaddr in the top level ip module but Vivado generated verilog files for PS7 IP specify DDR_BankAddr as a valid port. This difference in case is flagged out as an error by Vivado 2017.4
Re: Discrepancy in port name
How did you generate the top level module? Are you modifying it or letting the tool maintain it? I've not seen this error and I've done quite a few designs.
Brian Mulhearn - Director, Embedded Solutions
www.designlinxhs.com
Anonymous
Not applicable
There is no error but a request to put the correct port names with correct "case" in pg082 since verilog is case sensitive
