milan_mian
Do anyone has success with rebuilding Xapp794 design?
I am trying to rebuild the XAPP794.I downloaded the design file from here.
https://secure.xilinx.com/webreg/clickthrough.do?cid=199792
I got errors which running TCL scripts.
More details can be found on this page.
http://www.xilinx.com/support/documentation/application_notes/xapp794-1080p60-camera.pdf
pratham
@milan_mian what are those errors? please post vivado .log here
-Pratham
milan_mian
The logs are in attachments.
0 errors in synthesis and 9 errors in implementation(line 339 to line 350).
bwiec
It's having trouble finding the repo containing the hardware for the VITA receiver.
Can you try reducing your path length where the project is stored?
www.xilinx.com
milan_mian
@bwiec. Hi, I don't it is due to path. I have the design in the root folder. The cause of this problem is different. I wish the guy/gal who did the design could respond. Please
bwiec
I understand it's already in the root directory. If you look, you can see that the files are there. I've run into this error as well in windows. Please try putting the hardware/vivado/ directory into the root.
www.xilinx.com
milan_mian
@bwiec. Hi, thanks a lot for  your suggestion. The implementation ran much longer. Now, I encountered one more problem. The error is in from line 755 to 786
INFO: [Common 17-78] Attempting to get a license: Internal_bitstream
WARNING: [Common 17-301] Failed to get a license: Internal_bitstream
Parsing XDC File [C:/scripts/project/zvik_camera_2013.2.runs/impl_1/.Xil/Vivado-6424-W7-PI0598/dcp/design_1_wrapper_early.xdc]
Phase 0 | Netlist Checksum: 632963b4 read_checkpoint: Time (s): cpu = 00:00:59 ; elapsed = 00:01:00 . Memory (MB): peak = 1043.410 ; gain = 905.293 INFO: [Common 17-347] Attempting to get a license for feature 'Implementation' and/or device 'xc7z020' INFO: [Common 17-349] Got license for feature 'Implementation' and/or device 'xc7z020' ERROR: [Common 17-69] Command failed: This design contains one or more evalution cores for which bitstream generation is not supported. while executing "write_bitstream -force design_1_wrapper.bit " INFO: [Common 17-206] Exiting Vivado at Wed Jun 03 10:39:02 2015...
Could you please me help on this?
pratham
@milan_mian run this tcl command in console of the design  and share the result
report_ip_status
-Pratham
milan_mian
@pratham. Hi, you can find the result of report_ip_status in attachment.
pratham
@milan_mian I see there are 7 IP's which has the license status design_linking.
http://www.xilinx.com/support/answers/22108.html
http://www.xilinx.com/support/answers/30517.html
you need the license for these cores to generate the bitstream.
-Pratham
milan_mian
@pratham. Hi. this should not be a issue if I understand licensing well.(I have hardware evaluation license). I have attached screenshot of license status of those cores. Could you please check it?
pratham
@milan_mian Attach your tcl command output here
report_environment -file (path)
-Pratham
milan_mian
@pratham. Hi, I have attached the log of report_environment tcl script. Thanks.
ashishd
Check if this AR is helpful
http://www.xilinx.com/support/answers/58758.html
Ashish
milan_mian
@ashishd. Thanks for your reply. It does not help.
vuppala
Hello @milan_mian
report_environment doesnt have license information. So share the file generated after following below steps:
1. Open Command Prompt
2. Navigate to Vivado installation directory (for example: C:\Xilinx\Vivado\2013.2\ids_lite\ISE\bin\nt64\)
3. run the command: xinfo
4. Share the generated xinfo.txt here.
Vinay
milan_mian
@vuppala. Hi Vinay, Thanks for your suggestion. I have attached herewith xinfo.txt as you requested.
vuppala
Hello @milan_mian
The reason for the licnese issue is "Hostid mismatch".
You had license with hostid: 864bf5aa1b1c but whereas your system's hostids are: 5c260a7dff6f,d0df9ab2d567,081196579365,081196579365,081196579364,005056c00001,005056c00008
To resolve the license issue, generate the IP license again with any of the system's hostids.
Vinay
