Document for using this example design ar43677_sp605_axipcie.zip. I need
I am using Xilinx SP605 development board. I want to use PCIe interface. I want to use Micro-blaze, EDK based design.
I got example design ar43677_sp605_axipcie.zip
I need document for using this example design. Where I can get the same?
check this ARs
https://www.xilinx.com/support/answers/43677.html
Thanks and Regards
Balkrishan
