rmatsick3
Does the AXI4-Lite IPIF exist?
I found this nifty user to AXI-Lite core: https://www.xilinx.com/support/documentation/ip_documentation/axi_lite_ipif/v3_0/pg155-axi-lite-ipif.pdf
I looked for it in Vivado's IP catalog but could not locate it.  Has this been deprecated?
Rick
Tags (3)
dgisselq
As I recall, the IPIF interface has been removed from the IP directory.  However, if you look hard enough in ${INSTALL}/data/ip/xilinx/axi_lite_ipif*/hdl you'll find the relevant source directory.  At this point, I don't think Xilinx could easily get rid of IPIF--too many of their own IPs use it internally.
Personally, I find that the IPIF interface gets terribly throughput performance, and so I often find myself using this AXI-lite core instead whenever I need easy AXI-lite processing.
Dan
abouassi
Hi @rmatsick3,
Please check AR#62549.
Best regards,
Abdallah
dpaul24
@rmatsick3 ,
I would echo @dgisselq  comment.
Building your own core for any AMBA *Lite protocol is easy. It would be a simple state-machine where handshaking checks are going on. If you are an experienced developer, my opinion is to write it yourself.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
