ajasan
Doubts regarding AXI PCIE
I have some doubts regarding PCIe root complex port design in Zynq. KIndly clarify clarify below doubts
My design is a PCIe root complex.
1. M_AXI port of AXI PCIe logicore is for transactions  PCIe EP  ------> PCIe RP; S_AXI & S_AXI_CTL are for any master controllers' that drives communication b/w PCIe RP -------> PCIe EP. Is it true?
2. If so, where should the M_AXI port to be terminated?
Asan.
muzaffer
1) yes.
2) where ever the received data needs to be consumed. Probably a dma controller through which data is written into the DDR so that PS can read & process it.
ajasan
@muzaffer
Thanks for the response.
muzaffer
please close this topic if your question is resolved.
ajasan
I am trying to run a simulation using AXI PCIE, in S_AXI Custom master is sending data.
What needs to be configured via S_AXI_CTL port?
Now, axi_wready is not coming from S_AXI.
