jmonteiro-dme
EDK Interrupt controller test freezes
Everytime I run the selftest of a custom core with interrupt capability it freezes on the following instruction (tested with xmd):
  INTEST_mWriteReg(baseaddr, INTEST_INTR_IPISR_OFFSET, Reg32Value);
In hyperterminal I only see
Interrupt controller test...
   - IP (user logic) interrupt status : 0x00000000
   - clear IP (user logic) interrupt status register
Why is this happening?Any ideas?
Best,
JM
jmonteiro-dme
I have solved this by noticing a bug on EDK.
If the ISC is not selected in the peripheral create wizard, the created driver for the custom core still tries to write to a specific ISC register. This can be avoided by setting the C_INCLUSE_DPHASE_TIMER to 1 (easily set by right-clicking in the core in assembly view->Configure IP), which will allow timeout upon a unacknowledged instruction, as is the case. Therefore the freeze disapears as it overcomes writing to an unknown register if we don't activate the ISC device when generating the custom core.
Best,
JM
jmonteiro-dme
Best,
JM
