haas_fr
ERROR: DEVICEEN is 0
i'm new in using a Zynq Board and want to use FreeRTOS.
To getting started i just want to run the Demo Application. Therefor i had done the steps described here:
http://www.freertos.org/RTOS-Xilinx-Zynq.html
Now the problem is in starting the Debug Session. I get the Error "DEVICEEN is 0". So i've read following thread:
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Zedboard-Error-Deviceen-is-0/m-p/729164/highlight/true#M13708
If i follow Solution 1, i get this Error:
Solution 2 isn't the right Solution, because the sections are defined. I think in using the Demo Application it should be defined well:
Does anyone have an idea?
Thanks an best regards!
haas_fr
Referred to Solution 3, i have changed the memory mapping. Because i have seen the section "Interrupt vector table" in the link to the freeRTOS page:
Now i've set the memory mapping like this:
But nothing changed. Always the same error.
weicheng
   Did you got the solution to this problem, I got he same issue when I use lpddr2 on ZYNQ 7z100, would you please help me with this?
Thank you very much!
Yangao
