Execution Time in PowerPC.
I am trying to get the execution time of my code in PPC440.
#include "xtime_l.h"
int main (void)
   XTime start_time;
   XTime stop_time;
XTime_GetTime(&start_time);
My C program
XTime_GetTime(&stop_time);
elapsed = (double)(stop_time - start_time);
I get different timings each time i run the code!
So it cant be right way? Any suggestions ?
You can expect to see some small variations in the execution time for various reasons. To name a few:
  • The PPC440 has advanced features like Branch History Table and Branch Target Address Cache. They are used for instruction prefetching and are in a random state at the start of your program, i.e. influence the program execution time based on their initial state.
  • If your system uses interrupts, the number of interrupts and the time at which interrupts occur influence the execution time. For example, if you have n interrupts in one run and n+1 interrupts in a second run you will see a difference that matches the exception/interrupt routine execution time.
  • If your system uses external memory the number of refresh cycles on the memory matters. The start time of your program is not synchronized to the refresh cycle, i.e. similar to interrupts you can have n refreshes in one run and n+1 refreshes in a second run.
Any solution for that ?
In what way we can get the exact/approx execution time?
Anybody working with same ? Suggestions would be helpful.
How big is the variation that you are seeing relative to the execution time? Maybe, you can post some of your numbers?
I would expect your numbers to be very close to the average execution time and the variation should be relative small.
