abhijeetd
Eye Scan with MicroBlaze Processor MCS (XAPP743)
Hi, I am trying to bring up a proprietary High Speed IP on Xilinx V7 FPGA using the GT. I was planning to use the "Eye Scan with MicroBlaze Processor MCS" (XAPP743), for tuning the GT parameters. For this, I would sweep the DFE and CDR parameters and measure the corresponding eye for each value.
However, in the docs it says that only the equalizer settings (DFE/ LPM) can be tested. Can you please let me know if CDR can be swept as well thru this, and if so how can it be done.
pvenugo
Moved to appropriate board
kmace
Which board is that?
