FSBL and user application
I have a custom application and I want to make the zynq load rit from the QSPI memory.
The way to do that is to create an FSBL application, but I don't know how to integrate my custom application into it!
Thank you for your help.
Voyager
Voyager
Re: FSBL and user application
Once you have your application and your FSBL both created in the same work space, the next step is to create a boot image that can be programmed into the flash.
Check out this link for instructions on creating a boot image:
https://www.xilinx.com/html_docs/xilinx2018_1/SDK_Doc/SDK_tasks/task_creatingabootimage.html
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
Voyager
Voyager
