btmaas
Failing to boot vxworks with u-boot on Zynq-ZC706
I really REALLY hope someone can help me on this as I have been struggling to get this to work. I have been trying to boot a VxWorks binary image on my Zynq ZC706 board through U-boot(built from Xilinx U-boot source, v2013.04). The entry point of the vxworks image, I have confirmed, is set to 0x00100000 and I have been attempting to load VxWorks from an SD card by running the following...
1st attempt:
fatload mmc 0 100000 vxworks.bin; go 100000
2nd attempt:
fatload mmc 0 100000 uvxworks; bootvx 100000
* Note that here I wrapped a vxworks elf image with a u-boot header. The mkimage command I used was as follows:
mkimage -A arm -O vxworks -T kernel -C none -a 00100000 -e 00100000 -n "VxWorks Kernel Image" -d ./vxworks.elf uvxworks
3rd attempt:
fatload mmc 0 100000 uvxworks; bootm 100000
Many more attempts with varrying load addresses and commands (e.g. bootelf, go, etc). The only result I end up with is either an unresponsive terminal, data abort, or prefetch abort errors.
However, I ran a particularly aged version of u-boot(the command prompt says pele-boot, no saveenv command, ver 2010.09) per a coworker's suggestion and it worked by entering
However, this is not a viable solution for me because I need more commands offered by u-boot nor do I have the source for the older version of u-boot that I tried to use.
I hope to start a dialog with anyone that has run into diffculties with zynq/vxworks/uboot or anyone at all that could shed some light on the proper way to boot vxworks on a zynq-zc706 board. Many thanks in advance.
cch
You do not need U-Boot to load a vxWorks image. You can use the First Stage Bootloader provided in SDK.
Steps:
1. Create the default FSBL for the ZC706
2. Use the image creation utility in SDK. Specify the FSBL from step 1 and add your vxWorks image (rename it to vxWorks.elf first)
3. Use the boot.bin file created
cch
Steps:
btmaas
It worked perfectly! TY TY!
vincent_liu
Hi,I am a novice for vxworks from China ! I have got  a Zedboard of digilent company. And I have created BOOT.BIN by fllowing commands:
Step 1, Create bootrom.elf
 cd $(WIND_BASE)/target/config/xlnx_zynq7k
 make clean
 make bootrom.bin
and then, rename bootrom.bin to boottrom.elf
Step 2,Create a bif file
the_ROM_image:
       [bootloader]zynq_fsbl_0.elf
       bootrom.elf
zynq_fsbl_0.elf above is for Zedboard and it was made by Xilinx SDK14.4.
bootrom.elf was created in step 1.
I named this bif file "boot_bif.bif";
Step 3,Create BOOT.BIN
copy bootrom.elf ,zynq_fsbl_0.elf and boot_bif.bif to bootgen directory
run command :
bootgen -image boot_bif.bif -o i BOOT.BIN
after these 3 steps ,I have successfully created a BOOT.BIN
and then I copy it to a SD card and insert the SD card to Zedboard ,and Vxworks bootrom running well!
I have some questions:
1,the default memory map of this BSP(for xilinx zc-702 board,not for Zedboard) is as follow:memory maps
 I have got VxWorks bootrom running without any problem! Do I need to modify some address?
2,I have created "vxWorks","vxworks.st","vxWorks.sym".But I don't know chose which one and how to load vxWorks  from an SD card?
I do hope the friends who successfully transplanted vxworks to zynq can give me some  suggestion and  help me solve this problem! Thank you very much !
vincent_liu
I have solved my problem ! if you just want to setup vxWorks by SD card,bootrom is not  indispensable.You can put FSBL.elf  (for your specific eg: ZEDboard,zc-702,zc-706 )and vxWorks.st(not vxWorks!!!) to bootgen directory,and then rename vxWorks.st to vxWorks.elf.Now,you can enter these commands in a xilinx shell :
and then copy BOOT.BIN to your SD card! It works perfectly in my ZEDboard! Good luck :)
tameyama
Hello Vincent
I am also trying to run vxworks on Zedboard.
As you mentioned, "eg: ZEDboard,zc-702,zc-706 )and vxWorks.st(not vxWorks!!!)", vxworks.st is needed.
How can i get the vxworks.st file? By using workbench3.3/vxworks6.9, there is no option for me to create vxworks.st.  I can only generate vxworks file.
Any setting needed for this?
Regards!
vincent_liu
Hi,Have you got the vxWorks.st image?
salizaidi
Hello Every One,
I am lost in the plethora of documents from Xilinx, I need to load and boot Vxwork Image from SPI flash.
Can you guys help with the step by step procedure?, or point me to the relevent documents.
I am looking for board and sopftware configuration details to make SPI the primary boot device instead of SD card.
Also I would like to know FSBL creation procedure.
Thanks Alot.
Ali
Anonymous
Not applicable
I am using VxWorks 7. I would like to know if it is possible to boot it without using u-boot.
Also, How do we generate the vxWorks.st file?
I have the following files when I build the vxWorks image using Workbench4.
1) uVxWorks
2) VxWorks
3) VxWorks.bin
I dont have any vxWorks.st file. Did someone manage to boot vxWorks7 without using u-boot?
Any help would be appreciated.
Khizer
njohnston
Hey,
I was recently working on almost exactly the same problem (the only difference being I'm using the ZCU102 eval board) and managed to figure out a solution.  So, if you're still wondering how to boot vxWorks7 from the FSBL, here's how:
You'll need a petalinux project created from whatever BSP you're using.  If you've already tried to build and package your project, you should have a file under the build directory with a .bif extension (probably bootgen.bif).  That will be an auto-generated file based on your petalinux-package command, but you'll need to create your own by hand.  Basically, it should look something like this:
the_ROM_image:
        [fsbl_config] a53_x64
        [bootloader] /path/to/<your_board_specific>_fsbl.elf
        [load=0x100000,startup=0x100000] /path/to/your/vxWorks.bin
You may want to reference the .bif file that was generated from your petalinux-package command for the value of the [fsbl_config] setting...that may be specific to my board...not sure.
Given that load and startup address, you will need to configure your vxWorks kernel to use a RAM_LOW_ADRS of 0xffffffff80100000 and a RAM_HIGH_ADRS of 0xffffffff81000000 (which were the default values for the ZCU102 BSP).  Really, I think the RAM_LOW_ADRS comes down to whatever your LOCAL_MEM_LOCAL_ADRS is, plus the offset address (so, in my case, 0xffffffff80000000 + 0x00100000 = 0xffffffff80100000).  I think the RAM_HIGH_ADRS just needs to be high enough above the RAM_LOW_ADRS to not cause problems...still not 100% clear on how high that is exactly, but I've found 0x400000 to be plenty.  0x1000000 should definitely be enough.
You also need to make sure you are building the vxWorks kernel with the built-in DTB file.  Once you build, grab the vxWorks.bin file and put that somewhere you can get to with your petalinux-package command.
Then, package up your BOOT.BIN file:
petalinux-package --boot --force --bif <your_bootgen_file>.bif
And viola!  You should have a BOOT.BIN file that will boot the FSBL and then boot directly into your vxWorks image
LearningXilinx
@njohnston
Thank you, this worked for me....
