Floating point data calculation time
Hi, I am using SPARTAN-3E s500. starter board, with microblaze soft processor. I found the calculation time is different for the fix point data and floating point data. For floating point data, it is very slow,,,,,,anybody has any idea or this?
Best Regards,
Roy from the UK
Historian
Historian
Best Regards,
Roy from the UK
The MicroBlaze does not have a native hardware floating-point unit, so it does such calculations in software. And as such, one would expect performance to suffer greatly.
Thank you for your reply, any solutions except of using the fixed point data.
Best Regards,
Roy
As indicated, software implementation of floating point operations is much slower than fixed point due to the implementation differences in the operations.
However, there is a actually single precision IEEE-754 FPU configuration available with MicroBlaze (V2P and later). See the MicroBlaze user guide for additional information.
bt
Historian
Historian
Best Regards,
Roy
bt's suggestion of using the floating-point core is a good one, EXCEPT: it's a REALLY HUGE core.
Most engineers avoid the use of floating-point arithmetic in architectures that do not support it in hardware. You might wish to use a Virtex4 or Virtex5 device which includes the hard PowerPC; that processor has a floating-point unit.
It is also likely worth noting that the PPC FPUs are also implemented in fabric logic:
http://www.xilinx.com/products/ipcenter/apu_fpu.htm (APU Floating Point Unit)
http://www.xilinx.com/products/ipcenter/apu_fpu_virtex5.htm (Virtex-5 APU Floating Point Unit)
Granted, the Virtex devices are generally bigger (as well as faster and more $) than their Spartan counterparts so sometimes this is less of an issue.
There is the trade-off of resolution, performance, and device resource consumption when considering fixed vs floating point.
bt
Historian
Historian
bt
I stand corrected -- I haven't had a need for floating-point processing and I assumed that the PPC405 and PPC450 included a hardware FPU.
bt
Thanks you for your reply, do i need any special core for IEEE-754 FPU, looks like it is already included in the MicroBlaze?
Best Regards,
Roy
I'll admit I'm not the FPU expert...
But unlike the PPC cores which use the APU port as an interface to another peripheral, the MicroBlaze option appears to be part of the processor and configured by the appropriate parameter (C_USE_FPU) in the mhs. I assume the compiler also needs to know this to target the single-precision to HW instructions instead of SW emulation.
BSB (Base System Builder) asks you if you want floating point when you initially configure the MicroBlaze project - that is probably the recommended flow. Note that you can create a new project and have it import the old .bsb as a starting point.
bt
Based on the test, the FPU carried by the MICROBLAZE is not fast......
Will other FPU (Hardware) can improve the performance???
MicroBlaze FPU is roughly 1000 LUTs which is not huge although it's not tiny either.
It only supports single-precision so if you use double-precision, you will not gain anything.
But with single-precision you get at 100x improvement in floating-point operations which is a substantial improvement.
Göran
If you've verified that your hardware system has the optional FPU, and that you are indeed using single precision (float data types, not double, sinf() style functions, not sin()) then try using -ffast-math and/or -fsingle-precision-constant compiler options.  This will speed things up at the cost of precision.  If _thats_ not enough, MicroBlaze is probably not the solution for you.
-Brian
