FreeRTOS, AMP, XScuGic_InterruptMaptoCpu() with CPU_ID=1
(A) This is the initial C++ Application Project using CPU0:
> Vivado 2019.1
> Zybo Z7-20
> FreeRTOS, lwIP, and xilffs
> Includes 1KHz PL-PS interrupt
This project works fine
(B) I then created a second C++ Application Project that uses CPU1:
> Add -DUSE_AMP=1 to BSP extra_compiler_flags
(C) In an effort to start unloading CPU0, I attempted to service the PL-PS interrupt using CPU1.  Here is the configuration for that interrupt that runs on FreeRTOS/CPU0:
void enable_pl_ps_interrupt()
// FreeRTOS has setup the controller, only add the needed interrupt
XScuGic_Connect(&xInterruptController,XPAR_FABRIC_ZYBO_TIIDL_PL_0_KHZ_TICK_INTR,
(Xil_ExceptionHandler)TickInterrupt,
(void *)&xInterruptController);
XScuGic_SetPriorityTriggerType(&xInterruptController,XPAR_FABRIC_ZYBO_TIIDL_PL_0_KHZ_TICK_INTR,0,3);
//// Call the is being made, with CPU_ID = 0 or 1
////XScuGic_InterruptMaptoCpu(&InterruptController, CPU_ID, INTERRUPT_ID); // CPU_ID 0 or 1
//// this call works when CPU_ID=0, FreeRTOS
XScuGic_InterruptMaptoCpu(&xInterruptController,0,XPAR_FABRIC_ZYBO_TIIDL_PL_0_KHZ_TICK_INTR);
//// this call does not work when CPU_ID=1, AMP
//XScuGic_InterruptMaptoCpu(&xInterruptController,1,XPAR_FABRIC_ZYBO_TIIDL_PL_0_KHZ_TICK_INTR);
// Enable the interrupt for the device
XScuGic_Enable(&xInterruptController, XPAR_FABRIC_ZYBO_TIIDL_PL_0_KHZ_TICK_INTR);
I think this call can redirect the interrupt to CPU_ID 0 or 1:
The interrupt works fine if CPU_ID=0, but not with CPU_ID=1
I found two posts with updates for earlier versions of Vivado for XScuGic_InterruptMaptoCpu().  I tried both of those updates, with the same results.
The code as as shown uses the ISR in the CPU0 project when CPU_ID=1, and that may be problematic?  I then tried substituting the absolute address of an ISR in the CPU1 project.  Same results.
I found many other posts, mostly AMP-AMP and Linux-AMP, but nothing that addressed FreeRTOS-AMP.
QUESTION:
How and where should the interrupt resources be configured such that an ISR in CPU1 is called?
Dave
Follow-up, created new project with the same FreeRTOS, lwIP, and AMP setup, but without xilffs and application code.  Same results, interrupt works on CPU0, apparently never called on CPU1.
Apparently this is impossible, or maybe this was wrong forum?
PPI offer limited options, but do work.  SGI works when triggered from RTOS to AMP; haven't tested SGI trigger from inside RTOS ISR.
