thenumberdevil
GPIO setting freezes the pipeline
Hi all,
     When I register the GPIO driver, During the xgpio_save_regs  callback the GPIO IP is freezing the video capture pipeline.
Could not understand why?. Some pointers please?..
-nd
abhinayp
Hi @thenumberdevil
May I know if you are using the GPIO as reset pin for the video pipeline?
Also look at the below forum post if could help.
https://forums.xilinx.com/t5/Embedded-Linux/Xilinx-AXI-GPIO-Kernel-Hang-Not-Working-Zynq-UltraScale/td-p/988851
Please share the logs of the console.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
