amrs
Getchar problem with Microblaze, getting NULs after each character?
Hello, I'm not really a programmer, but I need to write simple test sw for an FPGA, so I'm using Microblaze. Much to my chagrin, I've run into a problem I can' t seem to solve. I input data from UART with getchar, but every character seems to be followed by a NUL. I don't really understand why? I guess I can work around this by throwing all NULs away, but I'd really like to know why this happens?
I have some test software from an older project (Virtex 4 FX, ISE 8.1 era, PowerPC instead of Microblaze) where getchar is used, but it doesn't seem to do anything special to get rid of extra NULs.
Example code, a simple input loop like this:
#include <stdio.h>
main()
  unsigned char mychar;
  while(1)
      xil_printf("Press any key...\r\n");
      mychar=getchar();
      xil_printf("You pressed %c (%x)\r\n", mychar, mychar);
If I run this and press 'a' on the keyboard, it prints this:
Press any key...
You pressed a (61)
Press any key...
You pressed  (0)
Press any key...
So it gets the 'a' and then a NUL, for some reason. I've tried different terminals, HyperTerminal and Putty, different boards, Spartan Starter and ML505. Seems to make no difference. Using EDK 10.1, SP2.
johnmcd
This is fixed in EDK 13.3
shuns
HI,
Do you hit return when testing this? Maybe something like this one.
http://www.soe.ucsc.edu/classes/cmps012a/Fall98/faq/scanfQ.html
amrs
shuns wrote:
HI,
Not hitting return, no, so shouldn't be any white space. Just pressing a random key produces that key and then the NULL. Pressing return seems to do the same, in fact, although it's hard to see from that printout since it actually prints at least a carriage return then.
I don't really understand how I could use that scanf example to fix my problem.
savadi
Good morning
i am working on EDk 9.2. i know in Xilinx  C, we use xil_printf for printf. But do use for scanf? How can I find this solution
hoosha
I have the exact same problem in EDK 12.3. Did you find a solution to your problm by any chance?
Thank you,
Hooman
robn
Try clearing the buffer with this command:
setvbuf(stdin, NULL, _IONBF, 0);
hoosha
I do that right before entering the loop for calling getchar() but it doesn't help. or should I do it everytime?
rickys
A simple get string function. Stolen from Terry.
int mygets(char *string){
	int x=0;
	int ret = -1;
	while(x != '\r' && x != '\n'){
	   ret++;
	   x=inbyte();
	   *string++ = x;
	*string = '\0'; // optional to add end of string symbol
	return ret;
johnli
Having exactly the same problem in 13.2 today. If you use RealTerm the NUL will be displayed.
A get string loop terminate at '/n' or '/r' will return an char array double the length of input with /0 between every char.
In you print the char array with xil_printf you will get ... the 1st char! (The string terminates with NUL)
Steps:
Try to use XUartLite_RecvByte instead of getchar, if not working try read HW's RX fifo and stat reg directly, to see if HW is indeed giving 2 bytes for each byte entered.
If the HW says 2 bytes, then it's likely a HW bug. Tape the uart rx signal to a 3rd party(or your own) uart softcore and verify only 1 byte is sent from the wire. This is obviously going to waste lots of time, so consider filter out all NUL returned from getchar as a SW workaround. (unless you are obsessed in exposing a Xilinx bug)
ASIC & FPGA/SoC designer
NYC HPC
johnli
XUartLite_RecvByte works, indicating a possible bug in getchar.
NYC HPC
johnmcd
I'm still seeing this problem in 14.1.
