06-26-2017 10:51 AM
Which are the pros and cons of using AXI HPC (high-performance coherent) w.r.t. HP (non-coherent) interfaces? Which interface is faster?
In the software, are cache flush and invalidation necessary only for the non-coherent interfaces? For example:
// Flush the cache
// **** Is this necessary only for non-coherent interfaces? *** Xil_DCacheFlushRange((INTPTR) input_data_stream, IMG_SIZE * sizeof(u32)); Xil_DCacheFlushRange((INTPTR) output_data_stream, IMG_SIZE * sizeof(u32)); XFilter_3x3_impulse_strm_Set_height_V(&Filter_3x3_impulse_strm, IMG_NROWS); XFilter_3x3_impulse_strm_Set_width_V(&Filter_3x3_impulse_strm, IMG_NCOLS); XFilter_3x3_impulse_strm_Start(&Filter_3x3_impulse_strm); // Data from the DMA (DRAM) to IP core XAxiDma_SimpleTransfer(&axiDMA, (INTPTR) input_data_stream, IMG_SIZE * sizeof(u32), XAXIDMA_DMA_TO_DEVICE); // Data from the IP core to the DMA (DRAM) status = XAxiDma_SimpleTransfer(&axiDMA, (INTPTR) output_data_stream, IMG_SIZE * sizeof(u32), XAXIDMA_DEVICE_TO_DMA); while (XAxiDma_Busy(&axiDMA, XAXIDMA_DMA_TO_DEVICE)) { /* Wait */ } while (XAxiDma_Busy(&axiDMA, XAXIDMA_DEVICE_TO_DMA)) { /* Wait */ } // Invalidate the cache to avoid reading garbage
// **** Is this necessary only for non coherent interfaces? **** Xil_DCacheInvalidateRange((INTPTR) output_data_stream, IMG_SIZE * sizeof(u32)); while (!XFilter_3x3_impulse_strm_IsDone(&Filter_3x3_impulse_strm));
06-27-2017 12:27 AM
Hi @gdg,
-> Refer to the TRM (UG1085) table 35-4
I would add the variable PL data bus width support (32/64/128) for HP.
-> The HP because it does not need to go through the CCI-400
-> For most of the systems yes. But you can have non-coherent transaction through HPC interfaces. But assuming you will keep AxCACHE[3:2] to any non-zero value then you won't need to flush or invalidate the cache.
Hope that helps,
Florent
06-27-2017 12:27 AM
Hi @gdg,
Hope that helps,
Florent
06-27-2017 10:43 PM
Do HP ports have higher throughput or just better latency ? Can you quantify what "faster" means here?
06-28-2017 01:01 AM
Hi @muzaffer,
You are right, "faster" is a bit too general. It is only less latency.
