xzt.1011
How can I create my own MFS file in the webserver application?
Hello, recently I am working on the ZYNQ-7000 Processing system, I want to write my own HTML file and Javascript file to transfer data between my PC and Development Board through the Ethernet cable.
Right now I have already done the example application provided by the file xapp1026, I can load the example web page in the browser, however, I do not need the toggle LED parts and switch parts, instead of that, I need a file upload part, so I need to modify the web form. The problem is that I cannot modify the image.mfs file inside the xapp1026, once I modify it, the web page is vulnerable to loading errors.
I also tried mfsgen -cvbf in the SDK shell too, however it can only be used for creating a new mfs file, what I want is to write content into the file!
Does anyone know how can I create my own mfs file?  I'll be really appreciated for your help!
stephenm
The flow is to use the mfsgen utility to include your custom files into the filesystem. What error are you seeing here?
xzt.1011
hello,
I have solved the problem by using the mfsgen command! thanks a lot ~
