bin9000
How can I read more than 1000-bit of data in BRAM at the same time?
If I create block memory generator, the bit-width of BRAM is set to 32-bit in maximum.
But, I want to read more than 1000-bit of data in BRAM at the same clock.
When I see the architecture of FPGA as below figure, I can see many BRAMs.
So I guess multiple BRAMs exist in FPGA, and I might access multiple BRAMs in same clock. My guess is illustrated in below figure.
If I create multiple Block Memory Generators as below figure, Can I access multiple data in BRAMs from PL side? My guess is right?
u4223374
Advisor
Advisor
Each block memory generator will represent at least half a block RAM (because a 36K block RAM can be divided into two 18K ones, and that is the smallest BRAM unit that Vivado will work with). Depending on the RAM size/width, Vivado may use multiple block RAMs.
In standalone mode (no AXI interface) you can actually specify a 1000-bit width on the block memory generator and it'll automatically use the necessary number of BRAM tiles.
u4223374
Advisor
Advisor
You can certainly access multiple BRAMs in parallel, but an AXI master can only talk to a single slave at a time - to access multiple BRAMs you'll have to skip AXI and interface with the RAMs directly.
bin9000
Thank you for your reply!
Then, my guess "2.each BRAM corresponds to each block memory generator?" in the figure is correct?
u4223374
Advisor
Advisor
bin9000
Thanks!!
Your reply is all I want!! Have a nice day!
