sourajitjash
How to access Vivado HLS exported PCore in Xilinx SDK
Hi all,
 I am following the designing matrix multiplication Accelerator based on Xapp1170. I am able to run it in standalone OS (Xilinx SDK). Now I want to do the same matrix multiplication using Accelerator in Linux OS. For the standalone case, in SDK I imported some driver files generated by HLS. But for Linux, is it possible to do following the same way? I found one file, named xmult_accel_core_linux.c for my mult_accel_core function. I want to know how to use this _linux.c file. Or whether I have to do something different. Thank You
siktap
The driver files might be different for the them. Just using the files, you would know if they need any changes.
Sikta
sourajitjash
I could not understand what you wanted to mean :/
So please elaborate and suggest how to access PCore from linux application in xilinx sdk. I could not find any tutorial
sourajitjash
