How to add Arm Cortex-A9 Based in to block design (vivado)?
HI
I want to use microblaze 10 interlink.
But i don't know add arm Cortex-A9 Based in to block design.
I use MicroZed System-On-Module (7020) board and program vivado 2017
thank
Hi @z0x0c0v0b0b,
You need to add a Zynq IP. This correspond to the Porcessing System part of the device which includes the dual Cortex-A9.
The you will target the specific core in SDK.
Hope that helps,
regards,
Florent
Florent
