How to add peripheral without Wizard?
Hello, how can i create and add my own peripheral without using the Create or Import Peripheral Wizard in my EDK system?
which steps to perform, and what to take in account?
thank u!
Historian
Historian
migliorin wrote:
thanks for the link, but i know about it, and it doesnt tell how to create and add custom peripheral... it is also about the wizard.
and i need to know how t create and add own custom peripheral without Creat and Import Wizard!
(for example in case if i want to use custom IPIF interface)
Ahh, creating and importing your own peripheral without the Wizard ...
If you have already created a peripheral, you can use it as a skeleton. You can modify the number of slave registers as required. Then you can add your own "user_logic" section that implements your peripherals.
You also need to modify the .mpd and the .pao files appropriately.
Make sure the whole mess uses the Xilinx directory structure and versioning. Put your hardware into the pcores directory. when you open your project in the EDK, your core will show up in the IP Catalog under "Project Local pcores" and is ready to be included in your EDK project in the usual way.
-a
I think you can refer to the blog <http://virtex2pro.blogspot.com/2008/02/create-project-using-base-system.html>
This provides you with an example.
Hem.
Historian
Historian
-a
thank you, but what do u mean by "Put your hardware into the pcores directory" ? do you mean to put my custom IPIF VHDL code in that directory?
and if i do this, is it possible to use that custom IPIF interface for my own peripheral, and simultaneously use XILINX IPIF interface with other Xilinx Peripherals in my EDK system?
thank u in advance!
Historian
Historian
thank u in advance!
By "Put your hardware into the pcores directory," I mean exactly that (please, RTFM) ... Xilinx imposes a directory structure on your EDK as follows:
project\system.xmp
       \system.mhs etc
          \drivers
       \pcores
And in pcores, you have to put your IP core as follows:
pcores\my_core_v1_00_a\data
pcores\my_core_v1_00_a\data\mycore_v2_1_0.mpd
pcores\my_core_v1_00_a\data\mycore_v2_1_0.pao
pcores\my_core_v1_00_a\hdl\vhdl\mycore.vhd
pcores\my_core_v1_00_a\hdl\vhdl\user_logic.vhd
And if you don't do it exactly right, the tools won't be able to find your core.
And yes, you can use the Xilinx IP cores at the same time that you use your custom core.
-a
